PostPosted: March 25th, 2015, 12:40 pm
Greetings. I'm new to XWidget and am trying to learn. I've downloaded the LG G2 and Galaxy S6 skins, and would like to know if there is a way to suppress the leading zero on the clock hour so that (in 12 hour format) it displays "4:37" and not "04:37". Thanks in advance.
PostPosted: March 25th, 2015, 1:17 pm
If it is a text component used to display the time you can change the format of the tag from
%Time0 (example:01:01)
to
%Time (example:1:01)
PostPosted: March 30th, 2015, 9:57 am
to
If I'm looking at this correctly, the object is an image, and in the Bind Core settings, though I see the "Time" tag you specify, this specifies a Core label of "num\${HourTens}.png". I guess with that setup there's no way to get rid of the leading zero. Bummer. Thanks.
PostPosted: March 30th, 2015, 10:01 am
Yes, if the 4 numbers are images you can't delete the first "zero"..
PostPosted: April 2nd, 2015, 8:38 am
Understood. I'm learning. I found a GS6 widget on XDA that has a text clock and modified it. I've also downloaded a number of your great widgets (GS Weather Transparent, Nature, ASUS Padfone 2 CW Original, My Atrix HD Widget V2, Acer Liquid S1 Cline v2) and tweaked them to add things like conditions text or update time or hi/low temps. They look great. Thank you.
PostPosted: April 2nd, 2015, 11:37 am
You're welcome sbs8331. I'm glad that you like my work! :)
PostPosted: April 2nd, 2015, 12:24 pm
I'll keep checking for new widgets. I'm not creative enough to create them, but I can tweak them. One tweak I made to the GS Weather Transparent was to change the sun images to match (extracted from) the Touchwiz widget seen here http://forum.xda-developers.com/showthread.php?t=2766014, as well as adding hi/lo temp and update time. Just my personal preference, as the images that came with the widget don't show up well on my device. Thanks again.
PostPosted: April 2nd, 2015, 1:45 pm
Great! You can use the forum here to upload your alternative versions, if you want, to "Share your creations" section.
PostPosted: April 2nd, 2015, 1:49 pm
OK. I didn't want to do anything inappropriate, given that they're just tweaks to your development.
PostPosted: April 2nd, 2015, 2:21 pm
In general, if you give credits to the original uploader, it's ok.
New ideas and new designs are always welcome. :)
