 Post subject: Weather Info
PostPosted: January 6th, 2015, 6:47 pm
Guys, no matter what I do, I can't get any weather widget to take my info. They continue to revert to Mount Laurel Township.
I live in Greeneville, Tennessee.
Please help.
Come see my work.
http://www.wincustomize.com/explore/all/pagesize/60/search/redneckdude
 Post subject: Re: Weather Info
PostPosted: January 7th, 2015, 1:14 am
First is this desktop XWidget or Android?
Do you have automatic location enabled?
PostPosted: January 7th, 2015, 8:18 am
It's a desktop XWidget. I don't know anything about automatic location, didn't see an option. If I click "location" when setting my location, it loads Mount Laurel Township in New Jersey. I live in Tennessee...lol.
Come see my work.
PostPosted: January 8th, 2015, 7:57 pm
Bummer.....no one answering this one?
Come see my work.
PostPosted: January 9th, 2015, 1:51 am
I searched for "Tennessee" in the weather/location screen and I received only a continuous loading and no results. I think that searching for "Tennessee" maybe is too general. Try to search on Accuweather.com and see if works and check the results.
I think that you shoud update to the latest version of XWidget though to avoid issues!
PostPosted: January 9th, 2015, 8:35 am
I searched Greeneville, Tennessee, not just Tennessee.
I have the latest version, and Accu Weather finds Greeneville Tennessee.
That said, I finally managed to clear the default location, and after that, was able to find mine. All is well. Took several days though.....shew...
Come see my work.
PostPosted: January 9th, 2015, 9:09 am
Hmm.. Maybe was a little issue.. Since you resolved it's ok.
Thanks for the report.
