PostPosted: September 30th, 2014, 5:05 pm
[Update log]
v1.92 2014-9-2
Add: XWidget.exe support cmd line to Show/Hide widget by widget's FolderName: showWidget:folderName, hideWidget:foderName, showHideWidget:folderName. etc: "d:\soft\xwidget\xwidget.exe hidewidget:htchome"
1. is it support show/hide of multiple widgets in one command?
if so then how?
2. is there any command available that can be used in code to do show/hide on other widgets (like msg() but without adding [OnMsg] event on other widget)
> i mean a command that execute inside Xwidget, without need of start another process
currently:
i'm using a loop to show/hide each widget by cmd line,
but this way there will be some problems:
1. it will start too many processes,
2. sometimes one of the processes get high on cpu Usage and hangs, and Xwidget will be hanged until i [EndTask] that process, then all the others will do correctly and Xwidget get back working,
PostPosted: October 1st, 2014, 3:42 am
Hi Hamid,
You can uses cmd line "msg" to batch show/hide multiple widgets in one command, for excample will send msg to all widget with "aaabbb":
d:\soft\xwidget\xwidget.exe msg:|aaabbb
if you need send msg to some widget with a folderName excample "eker_note", then uses:
d:\soft\xwidget\xwidget.exe msg:eker_note|aaabbb
Tony
hamid wrote:
[Update log]
v1.92 2014-9-2
if so then how?
currently:
PostPosted: October 1st, 2014, 9:40 am
thanks for the info Tony,
but still i didn't find the answer,
i mean to have 2 or more folder name in one command,
is there anyway to separate folder names in one command?
for example:
"d:\soft\xwidget\xwidget.exe hidewidget:netmeter,clock,calendar,sysinfo"
PostPosted: October 4th, 2014, 8:50 pm
Hi hamid
I can not try it because I am not using the latest version but did you try, in a function
run("c:\pathto\xwidget\xwidget.exe hideWidget:folder1name|widget1name");
run("c:\pathto\xwidget\xwidget.exe hideWidget:folder2name|widget2name");
run("c:\pathto\xwidget\xwidget.exe hideWidget:folder3name|widget3name");
etc.
Or is this what you mean by
PostPosted: October 5th, 2014, 7:54 am
yes, i'm using same way but with Open2("","") function,
and it will have these problems:
also there is another problem:
3. on [showwidget] command, the opacity of widgets will be 100%, until i mouse over widget
PostPosted: October 10th, 2014, 1:40 am
Hi Hamid,
You can uses cmd line "msg" to show/hide 2 or more widgets in one command, for excample will send msg to all widget with "hamidmsg_aaabbb":
d:\soft\xwidget\xwidget.exe msg:|hamidmsg_aaabbb
and then you can write script in your 2 or more widgets to get the msg text and check wether contain perfix "hamidmsg_" , if yes then do action.
etc pseudo-code:
function widgetOnMsg(msg){
if msg begin with "hamidmsg_" then {
do some action
for example:
PostPosted: January 16th, 2015, 8:47 am
This pipe character '|' causes issues. It is used as a shell piping separator and thus is a reserved symbol.
This doesn't work. You MUST change that '|' to someting else
