PostPosted: June 10th, 2014, 12:44 pm
Hello, please is possible if I have xwidget with XLaunchpad and I add some widget on board and in XLaunchad I have 2 screen with icons then I want keep this one widget on first page. And when I switch second page a widget stay on firts page? Fanks for answer.
PostPosted: June 10th, 2014, 4:49 pm
we can't add xwidget widget to xlaunchpad.
PostPosted: June 10th, 2014, 6:04 pm
You can use XWidget and XLaunchpad together! ;)
PostPosted: June 10th, 2014, 7:17 pm
he wants to use XlaunchPad and when changing the page in Xlaunchpad one of the widgets in Xwidget show/hide;
so he is already using both of them together
i have never used Xlaunchpad so i'm not familiar with it,
but i don't think there is any link available between these softwares to do so.
but about Xwidget,
if you are familiar with Creating widget,
you can create your own Xlaunchpad widget in Xwidget (create a dock widget for Xwidget)
and then using the msg() function in your dock widget you can send show/hide messages to your other widgets
more info about msg() function:
http://bbs.xwidget.com/viewtopic.php?f=7&t=43#p95
Note:
i have never used or tested the msg() function,
so i don't know if it works in current version or not
