PostPosted: April 19th, 2014, 8:07 am
Let's say I have one text area, and I want to show Weather in it, then have the weather vanish and an RSS feed show up instead. And I want it to loop between these two things. Right now I'm trying this code:
talklayer.Visible=true; //is the text area  supposed to be visible?
function hideInfo() // hides both the weather info and RSS info layers
Weather_Info.Visible = false;
RSSText1.Visible = false;
function exchanger()   // called at widget load
while (talklayer.Visible==true)   //is the text area visible to the user
hideInfo();                                              // empty the text area
RSSText1.Visible = true;                        //show me the RSS feed text
sleep(1500);                                         //leave it up for a while
hideInfo();                                            // hide  all text
Weather_Info.Visible = true;                //Show me the Weather text now
hideInfo();                                          //hide all the text
sleep(1500);                                      //wait, repeat on loop
My problem is using this code both layers show up simultaneously and they won't turn off. Am I doing something wrong? Is there a better way to rotate between text layers?
PostPosted: April 19th, 2014, 9:04 am
1. it's better to use while(talklayer.visible) than while(talklayer.visible==true)
2. I think that it's dangerous to combine while and sleep especially when you call them at widget load.
3. my solution:
use a timercore whose interval is 1500 ms to exchange weather and rss.
function timercore1OnUpdate(Sender)
  if(talklayer.Visible)
    Weather_Info.Visible = !Weather_Info.Visible;
    RSSText1.Visible = !RSSText1.Visible;
PostPosted: April 19th, 2014, 9:24 am
This is the "magic" with the script: you can do the same thing with only two lines of coding!!! :lol:
PostPosted: April 19th, 2014, 12:13 pm
Thanks for all the help! :D
