PostPosted: April 9th, 2014, 11:25 pm
thanks for so much beauty just found out the xwidget
i just wonder i use 2 Original windows gadgets i prefere very much
one for daemontools light and one for rain report in the Netherlands called buienradar that connect to internet page9official gadget from this site
is there a way to convert these gadgets so i only use xwidgets in future
much greetings
PostPosted: April 9th, 2014, 11:42 pm
there is not a convert method,yet.
you can make a same widget for XWidget.
this is what jimking have done : http://www.deviantart.com/art/Windows-V ... -409728691
PostPosted: April 9th, 2014, 11:55 pm
thanks for the reply
i am not good at programming so not an option for me :(
buienradar the dutch site has a lot of gadgets i mean for differentplatform etc but i don't know how to do anything to get it in xwidget http://www.buienradar.nl/home/textpage?pagename=gadgets
PostPosted: April 10th, 2014, 2:46 am
I was ready to post the link for my "Windows Vista-7 Gadgets PACK" as qiancang did! :lol:
I checked the dutch site but as I see all the gadgets are the same. Are weather widgets with a live weather/map.
Thank you for the link but I suggest you to search here or on Deviantart and will find a LOT of weather widgets/port from Android,Rainmeter or XWidget's original widgets. ;)
PostPosted: April 11th, 2014, 1:28 am
thanks for reply
so far i managed to make something with html in html-panel(a code from the site for use in webpage)
just if I resize only the frame resizes not the html-panel( i think because of the html code wich inludes the size
PostPosted: April 11th, 2014, 2:13 am
I made some widgets in the past with html panels. Yes, unfortunately there is this little problem..
Read this:
viewtopic.php?f=3&t=3128
