It is currently October 23rd, 2026, 4:50 am
PostPosted: April 2nd, 2014, 7:25 am
About couple weeks ago i installed xwidget from CNET? Im not sure, but anyway after installing i noticed registry helper on my computer. After that i removed first xwidget and then couple hours later finally registry helper too. So i would like to install xwidget again without malwares or whatever, but is it safe downloading the setup from here? Is it clean? :shock:
Sorry my bad english,
Heke
PostPosted: April 2nd, 2014, 7:34 am
Please read these:
viewtopic.php?f=2&t=2
and
viewtopic.php?f=3&t=3732
Remember that you should download/install XWidget only from here:
http://xwidget.com/
PostPosted: April 2nd, 2014, 7:46 am
thank you for prompt answer! Is portable version as good as installed version? Do i see any differences?
PostPosted: April 2nd, 2014, 8:06 am
No heke. Is the same as the installed version. Is "portable" so will not install any files on your pc.
PostPosted: April 2nd, 2014, 8:15 am
yeah, thanks... the portable version is running now.
PostPosted: April 2nd, 2014, 8:20 am
You're welcome.. :)
Users browsing this forum: No registered users and 113 guests
