 Post subject: Widget Size
PostPosted: March 24th, 2014, 2:53 pm
Is there a way to change a widgets height and width from a function within the widget?
What I'm asking is can I do something like Widget.Width = 578; from within a function and have the widgets width change to that?
 Post subject: Re: Widget Size
PostPosted: March 24th, 2014, 6:07 pm
Or is there a way to scale animated gif's?
PostPosted: March 25th, 2014, 3:19 am
Topic moved in "Help: XWidget Application" section. Please select the right section.
Now about your question, you can use: (right click on the widget)
1) Window -> Zoom
2) Configure -> Position & Size.
I suggest you to use the first option though to not alterate the real dimensions of the widget.
PostPosted: March 26th, 2014, 5:02 pm
What I'd like to do is change the size of the widget during runtime based on the size of a animated gif, or scale a loaded gif to match the size of the wdget.
PostPosted: March 26th, 2014, 5:09 pm
Sorry but you mean to change the size of the widget when runs on the desktop, or using the designer, so you ask help for the Designer process..
PostPosted: March 27th, 2014, 2:46 pm
yes, it can be done exactly same way as you said,
in the script editor, just place the lines of code in a function and call the function in some way:
- you can call the function by clicking on a button (button1OnClick);
- you can call the function on widget start (widgetOnLoad);
- you can call the function from another function;
- and .....
example:
//don't forget to add function name [button1OnClick] in the [OnClick] of [Button1] Object in the function tab of Designer (to call button1OnClick function when button1 Clicked)
function button1OnClick()
  widget.Width = 578;
  widget.Height = 480;
