PostPosted: March 17th, 2014, 1:32 pm
Two questions.
1.) How can I move the dashboard from displaying on one monitor to another? I have three screens and I'd like the dashboard to open on my main (centre) monitor.
2.) Where are the coordinates for the Editor program window stored? The Editor opens somewhere off my screens! I used to have a fourth monitor, but I had to cut down to three as my new video card can't run four monitors. The Editor is open, but not where it can be seen. I assume it is using the coordinates of the now missing fourth monitor. I need to find some way of changing/resetting where the Editor opens.
I've tried uninstalling, registry cleaning and reinstalling XWidget, but this has made no difference. The dashboard still opens on the 'wrong' monitor and the Editor opens somewhere it can't be seen. Its icon appears on the taskbar and it appears in the taskbar preview, but I can't make it appear on any monitor! :-(
Clues would be appreciated.
Thanks,
Glyn.
PostPosted: March 17th, 2014, 1:46 pm
what is your graphic card brand?
i think you should find these settings in driver settings window of your graphic card.
PostPosted: March 17th, 2014, 2:05 pm
This will have nothing to do with the graphics card or its drivers.
The XWidget software is storing its window coordinates somewhere; either in a file or in the registry. Once I know where, I can reset them and get the Editor window appearing on-screen.
PostPosted: March 17th, 2014, 2:22 pm
Like hamid said I don't think that Xwidget as a simple program can affect all this.. I think that you should check your PC configuration. Cleaning registry, re-install or any other method like these are nothing to do with your problem..
The only Xwidget folders are in the "program files" and in "My documents"
Users browsing this forum: No registered users and 144 guests
