 Post subject: Sustitute 00:00 ?...
PostPosted: December 11th, 2013, 6:42 am
How can sustitue "00:00" with "plug" into the text settings.
Because ":" is used as code...
I don't know if I am clear... sorry
Thanks!
 Post subject: Re: Sustitute 00:00 ?...
PostPosted: December 12th, 2013, 9:02 am
Thanks!
i don't understand your question correctly...
but if you mean using ":" in "00:00" in the script code:
you can use 00:00 in the "" and it will be translated as text: "00:00" and will be shown: 00:00
also you can use plus sign [+] to attach more than one text, like this: "00"+":"+"00" that will be shown: 00:00
PostPosted: December 12th, 2013, 1:40 pm
Thanks for your patience!
What I'm traying is this:
I want that when the "lifetime" battery (remaining charging time) is equal to "00:00" instead of showing that (00:00), that text be replaced by the text: "FULL".
Usually I can easily replace a text, using the "sustitute" function.
The sustitute function uses ":" to indicate that what is after the colon replaces what is before the colon...
So if precisely what I want to replace is a text which includes the colon ... I have a problem ... Is now understand?
Sorry, but I'm not good with English! ...
PostPosted: December 12th, 2013, 4:54 pm
i think the function you are using is "substitute" or maybe its different in other languages
anyway, i couldn't found a way to use ":" in substitute
but you can use another way to do that:
in the functions tab in designer there is a Event "OnChange" for text objects
use it and add this to the code for it:
function text1OnChange(Sender)
  if(text1.Text=="00:00")
    text1.Text="FULL"
PostPosted: December 13th, 2013, 1:51 am
Simply genial :) !!!!!
Thanks you very much Hamid!!!
Armando
PostPosted: December 17th, 2013, 5:40 am
I have a problem: when Text1.text it's no equal to "00.00" (it's change) what code I should write?
Something like this:
text1.Text=" "
else
text1.Text=text1.Text;
But this script doesn't work.
Can you help me?
Is writing correctly the "else" instruction?
Thanks!
PostPosted: December 17th, 2013, 4:02 pm
you don't need to write [else] for your above code,
because text1.Text is always equal to text1.Text;
it's not a need to use [else] command after each [if] command.
so if you want text1.text change only if it is equal to "00:00"
you could doing only with if command (no need of else command):
text1.Text=" "
but if you want to change text1.Text for other conditions than "00:00":
then you will need [else] like this:
text1.Text=" "
else
text1.Text="something else"
and also if you want to change text1.Text only if it's not "00:00"
then you will need to use "!=" (this means not equal) instead of "==" (this means equal):
if(text1.Text!="00:00")
text1.Text="this is not equal to 00:00"
