 Post subject: uppercase via script
PostPosted: September 19th, 2013, 11:38 am
I would like to know how to get uppercase via script?
I've tried already "object.style.fontVariant="uppercase", but it doesn't work.
There is "js_function strVariable.toUpperCase() :string" in the "Script Auto Complete" - popup menu, but how exactly does this work?
 Post subject: Re: uppercase via script
PostPosted: September 21st, 2013, 5:53 pm
Does this help ?
function button1OnClick(Sender)
var OLDTEXT = " testing case conversion method ";
var NEWTEXT = OLDTEXT.toUpperCase();
alert(NEWTEXT);
PostPosted: September 22nd, 2013, 6:34 am
Hi meme,
thank you for your help! Your script works fine but it isn't exactly what I mean. I only want a change from lower case letters to upper-case letters, but no alert. I could do this by using two different texts and hide/show text1/text2 etc., but I would prefer a solution via script if it is possible. It would be great if you know how to get this. :)
PostPosted: September 22nd, 2013, 6:23 pm
I am not sure when you want the case to change, but this code from a button press will change the case of text1.
var OLDTEXT = text1.text;
text1.Text=NEWTEXT ;
or in one line
text1.Text=text1.Text.toUpperCase();
PostPosted: September 23rd, 2013, 1:49 am
Yes, that's exactly what I want. Thank you very much!!! :D
PostPosted: October 21st, 2013, 4:12 am
What about these?
text1.UpperCase = true;
PostPosted: October 21st, 2013, 7:50 am
This works perfectly too! Thank you! :)
