 Post subject: Help with Timed Shutdown
PostPosted: June 21st, 2012, 2:58 pm
Hi, I am trying to create a widget that will allow the user to set a time that the computer will shutdown every night.
This code works, shutting down at the set time and asking the user to abort the shutdown if required.
But if the user does not respond to the "Confirm" abort shutdown request it will remain active, while the system is shutting down.
Is there a way to dismiss the confirm request with a setTimeout? or another method all together ?
Thank you for your help :)
function TimedShutdown()
var NowDate = new Date();
var NowHour = NowDate.getHours();
var NowMin = NowDate.getMinutes();
var OffHour = NowHour; //OffHour will be set by user
var OffMin = NowMin; //OffMin will be set by user
if(NowHour == OffHour && NowMin == OffMin) //shutdown if time match
run("shutdown.exe -s -t 60");
//setTimeout("doSomething()",10000); //can it be used to dismiss the confirm ?
var answer = Confirm("Abort Shutdown ?") // ask user to abort shutdown
if (answer)
run("shutdown.exe -a");
PostPosted: June 21st, 2012, 9:55 pm
hi,meme,nice to meet you
some main code:
function timercore1OnUpdate(Sender)
var OffHour = parseInt(edit1.text);
var OffMin = parseInt(edit2.text);
timercore1.Enabled=false;
if(confirm("shutdown"))run("shutdown.exe -s -t 60");
else setTimeout('dosomething',10000);
function dosomething()
if(confirm("shutdown")) run("shutdown.exe -s -t 60");
shutdown.rar [8.14 KiB]
Downloaded 456 times
PostPosted: June 22nd, 2012, 2:38 am
Thanks again qiancang for your assistance, very helpful.
Greatly appreciated :D
