 Post subject: Dashboard issue
PostPosted: June 16th, 2013, 12:39 am
Hi!
I'm having a little problem I have tried everything now and searched everywhere but can't find an answer so I hope someone here can help.. :)
So, I'm running XWidget on Windows 7 with dual monitors.
My problem is that when I for example play a game on screen #1 after about 5 minutes the dashboard will automatically activate on my other screen, which disrupts the game a bit... So I'm wondering if there is some way to disable this so that I just have the widgets as normal on my screen and that annoying dashboard doesnt pop up all the time..
Thank you for ANY help... :)
Gullfisk <3
 Post subject: Re: Dashboard issue
PostPosted: June 16th, 2013, 3:00 am
i found the problem, its because in the game i sometimes spam my scroll button which activates it....
where can i change the keybinding for this?
PostPosted: June 19th, 2013, 5:20 am
Right click on the tray icon and select "Option...". There can edit the dashboard's options.
