 Post subject: confirmations
PostPosted: June 11th, 2013, 11:01 am
i want to ask how i can to edit a widget that want a confirm for do something for example recycle bins when i want to clean recycle bin ask me "clear recycle bin"..when i use a widget to shutdown pc ask me if i am sure etg
 Post subject: Re: confirmations
PostPosted: June 11th, 2013, 4:29 pm
Open the "On Click" list with the codes and you will see the various with/no confirm codes.
PostPosted: June 11th, 2013, 6:19 pm
u did it for recycle bin excellent for shutdown button i make changes using edit but i haven't test it...ok thanks anyway
