PostPosted: April 12th, 2013, 4:14 am
Hi!
I whant to change the progress bar color by script code.
how should I do?
This script might work?:
progressbar1.foregroundfill.solidcolor = rgba(103,103,103,255);
Thanks in advance!
PostPosted: April 12th, 2013, 6:22 am
foregroundfill solidcolor
progressbar1.fore.draw.solidcolor = rgba(103,103,103,255);
backgroundfill solidcolor
progressbar2.back.draw.solidcolor = rgba(103,103,103,255);
facebook:http://www.facebook.com/ZhaoKenneth
weibo:http://weibo.com/102030456
twitter:http://twitter.com/colawings
DeviantArt:http://kenneth117.deviantart.com/
PostPosted: April 12th, 2013, 9:11 am
Hey Kennet, thanks but doesn't works for me.
Can you check it? thanks again!
PostPosted: April 14th, 2013, 4:46 am
Any other help to change color of progress bar by script code?
PostPosted: April 14th, 2013, 6:30 am
try this:
progressbar1.fore.draw.solidcolor.color = rgba(103,103,103,255);
progressbar2.back.draw.solidcolor.color = rgba(103,103,103,255);
PostPosted: April 14th, 2013, 6:47 am
YESSSSS!! it works ;) Thanks Tony!!
Users browsing this forum: No registered users and 163 guests
