It is currently October 23rd, 2026, 1:10 am
PostPosted: April 11th, 2013, 6:38 am
Hello! I'm new here and the main reason I got XWidget was I wanted to have multiple (4) digital world clock(s) on my desktop.
It doesn't have to fancy, and I could use same clock as long as it says the name of the location with the time... I like simple clean easy to read digital (24-hrs) clocks.
Originally, I downloaded the "HTCHome" weather clock by siyu35, because I liked the time and weather with forecast. But as I changed the location, the time remained the same... it didn't make a sense to have unmatched information...
Does anybody know if there is a digital world clock with weather info, or just a simple digital world clock with location name on the clock???
Thank you and I look forward to hearing a good news! :)
PostPosted: April 11th, 2013, 5:13 pm
Hi ymaz, If you need digital (24-hrs) world clock, just download digital clock from XWidget's gallery
etc:
http://xwidget.com/xwidget/widgets/date ... 1/339.html
http://xwidget.com/xwidget/widgets/date ... 0/391.html
http://xwidget.com/xwidget/widgets/date ... 1/400.html
Or if that clock not support time zone change, you can right click the widget and select "Edit",then you can add time zone support by your self:
1. left side click "Menus"
2. center ,click add MenuItem
3. set thie menuitem caption ,and select core "datetimecore1" and select OnClick event "!ShowSetting"
PostPosted: April 13th, 2013, 6:32 am
Hi Tony,
Thank you very much for the recommendations for the world digital clocks, but they are missing one important component... The display of the location...
As for the editing, I tried to apply for the one I downloaded (HTCHome" weather clock by siyu35), but the time displays doesn't reflect the location I select... :(
I want to set up 4 digital world clocks (Arizona, Ocean City/NJ, London, Tokyo) on my desk top possibly with weather forecast...
Yumi
PostPosted: February 21st, 2016, 10:37 pm
Initially, I downloaded the "HTCHome" climate clock by siyu35, in light of the fact that I enjoyed the time and climate with gauge. In any case, as I changed the area, the time continued as before... it didn't bode well to have unmatched data...????
== http://www.win-on-slots.com/ ==
Users browsing this forum: No registered users and 76 guests
