PostPosted: March 20th, 2013, 3:55 pm
(sorry form my english!!!))
ABOUT THIS PIECE OF CODE:
function rsscore1OnUpdate(Sender)
icon1.Hint = text1.Text;
Well, then, I have a question about this piece of code above: when the rsscore1 is automatically updated, icon1 will is shown a "hint" with the title of the RSS and its corresponding description?
What I want? I want to do that: when de rsscore automatically updates, the icon1 (image) show a hint with the same text as text1 (text). In turn, text1 has as "binding core": rsscore1, and the "format core data" %item1_title %item1_description
Thanks!!!
PostPosted: March 20th, 2013, 6:43 pm
Do you mean the icon1's Hint auto display when rss update?
but the icon1's hint only displayt when you mouse hover on icon1.
I think you can add a image control A and load a PNG image looks like a Hint, and place a text control B on the A, and set A invisible
when rss update , you set the B text and make the A visible, etc:
B.text = text1.Text;
A.visible = true;
PostPosted: March 21st, 2013, 3:39 am
Thanks TONY!
I being trying, but i can't.
I made this test widget. But don't works! Could you see it and correct it?
THANKS!
RSSautoshow.XWidgetPkg [557.55 KiB]
Downloaded 395 times
PS: I add some elements like button just to test the effect
