PostPosted: March 3rd, 2013, 3:00 am
Hi
I have downloaded the HTC Weather Widget but I noticed, that it is not possible to adjust the local time at the city chosen to be shown. For example: My local time is 11:56AM (GMT + 1:00) and when I chose New York as a city to show its weather, the time did not change - it was still 11:56AM. Is it possible to add a feature, which adjusts the world time to the cities. Thanks in advance. :D
PostPosted: March 4th, 2013, 4:54 am
HI,noir, the time is controled by the datetimecore. You need to change its timezone at the same time.
PostPosted: March 4th, 2013, 11:02 am
Hi qiancang
Thanks for your feedback. I have changed the timezone on the datetimecore and I saved the changes, too, but after activating the widget, it still shows me the local time in my country. I have attached here a print screen of the "situation". The local time in New York should have been 13:56 :cry:
How can this problem be solved?
Users browsing this forum: No registered users and 163 guests
