 Post subject: xwidget disappears
PostPosted: January 20th, 2013, 9:19 am
I'm using xwidget on a WinXP machine and am finding that after returning from hibernation the xwidget isn't displayed. When I bring up the dashboard they are shown, but when I close the dash they disappear again. Even after a restart of xwidget the widget still doesn't show up.
The only widget I'm trying to use is the HTC Home one. I've tested with other wdigets and the same thing happens.
Everything had been working fine for some time, but has recently started to do the above. I thought it was an issue with the new 1.8 version so I rolled back to 1.7.5, but have found that the same problem is happening with both versions.
Any tips?
 Post subject: Re: xwidget disappears
PostPosted: January 21st, 2013, 3:09 am
1. show Dashboard
2. right click widget,and select "Show on desktop"
