PostPosted: January 12th, 2013, 6:57 am
This morning i download the Xwidget 1.80. My Avast infectec the gallery.exe is
Win32:Malware-gen
And i scan with the Virustotal (4/46)
https://www.virustotal.com/file/36214dd39ea5e4f4043ffa9787dd7aac1f964b6fbed9e3c7b18197e6256e5033/analysis/
VirSCAN (1/37)
http://r.virscan.org/report/3a65269bd400921e2d21cebc4bca0e44.html
Plese help me. Because i with the Rainmeter.It's so hard. XWidget is easy than that!
PostPosted: January 12th, 2013, 7:53 pm
Just a False positives.
[Virus Scan reports]
There are some antivirus software false positives, this is a virus scan report,It is clean.
http://r.virscan.org/report/98cbc570313 ... 7bf66.html
http://r.virscan.org/report/8ea34bac578 ... 23c67.html
http://r.virscan.org/report/948791529ec ... 2138d.html
http://r.virscan.org/report/914e1fe6039 ... de2f2.html
http://r.virscan.org/report/54e019b8d6f ... 23313.html
Please check this virus scan report by Avira, It is CLEAN: http://analysis.avira.com/samples/detai ... id=1149966
http://analysis.avira.com/samples/detai ... id=1175708
PostPosted: January 13th, 2013, 12:02 am
Tony wrote:
You scan is 2012/06/11,2012/05/08,2012/03/31 . This file is 2013/1/10
PostPosted: January 13th, 2013, 12:10 am
This is scan 2013-01-11 02:30:59 UTC
https://www.virustotal.com/file/5dc01b8 ... /analysis/
PostPosted: January 13th, 2013, 5:26 am
tdtv-bkt432 wrote:
OK, I upload and scan it now, this report: http://r.virscan.org/report/a635111088d ... 43910.html
Only the Avast! and ClamAV give the "False Positives ", but the ClamAV is a software for UNIX platform, not for windows .
I had submit galler.exe to Avast! to here: http://www.avast.com/contact-form.php?l ... es&subject
Because the gallery.exe file is the in-app gallery, it used a IECore/WebBrowser control to display gallary , and when you select widget the gallery.exe will help you to download the widget and install it into XWidget and show on your desktop, This function is very sensitive, very easy to be False Positives .
If you do not need In-app widget gallery, just delete file "Gallery.exe" , and just download widgets with your bowser from http://xwidget.com/widget/
Users browsing this forum: No registered users and 147 guests
