PostPosted: January 4th, 2013, 11:48 pm
I wish to make a dock style widget similar to TSF UI Shortcuts Folder Box which can be found at http://xwidget.com/xwidget/widgets/system/2012/0415/249.html
But the features that I would like do not seem to be available, they are:-
1 - To drag a shortcut or url to a certain position and have it stay there so it is not moved by adding or deleting other shortcuts.
2 - To be able to drag shortcuts from one position to another, without affecting the position of other shortcuts.
Can anyone suggest a way this could be done?
When using a ShortcutListCore it always seems to sort the list when adding or deleting shortcuts.
Using many ShortcutCores provide fixed locations but none of the other features I would like.
My aim is to end up with pages of shortcuts with page tabs
Say 50 URL links, 50 of OFFICE documents, 20 for GRAPHICS applications, 20 for GAMES and so on...
I know this is similar to Xlaunchpad but it would be good to be able to customize it the way you want it.
Thanks for any opinions or advise.. :D
PostPosted: January 7th, 2013, 4:59 am
@ 2nd item: There is a script by qiancang which allows to move controls. viewtopic.php?f=10&t=25
PostPosted: January 7th, 2013, 4:39 pm
Hi Dagedee
Thank you very much for your assitance
I would very much like to look at your widget "Minipad" but am unable to find it...
The page at http://dagestuff.deviantart.com/gallery/#/d5chqf9 give me a link to http://www.xwidget.com/ but I am unable to find it. Can you tell me where to download it from ?
Once again thank you :D
meme
PostPosted: January 8th, 2013, 3:00 am
Hi meme,
that's strange ... however I'm attaching "Minipad" here :)
minipad.rar [185.28 KiB]
Downloaded 524 times
PostPosted: January 8th, 2013, 11:59 am
Thank you...
