PostPosted: December 30th, 2012, 2:00 pm
It doesn't work. Is it because I'm from Ukraine?
PostPosted: December 31st, 2012, 3:16 am
Hi, it works - (excepting "HitFM"). You have to change "Radio URL" as explained here ↓
radio_example_url.zip [287.84 KiB]
Downloaded 589 times
PostPosted: December 31st, 2012, 6:39 am
I do everything right but nothing is playing. Even originaly put ORS Radio Top 40. I have recorded video how I set stations - http://youtu.be/WVHdbJteWCA
PostPosted: December 31st, 2012, 7:14 am
Everything looks right how you are doing it ... the example radio doesn't work either? I used this url: http://bbc.co.uk/radio/listen/live/r1.asx
of BBC1 - it works fine.
PostPosted: December 31st, 2012, 7:53 am
There is no any working radio :(
PostPosted: December 31st, 2012, 9:44 am
I think it is because of the urls, not every url works, because radio stations are changing them from time to time, as I've read in the web just now.
All of these radios are working fine with an up to date radio url.
http://xwidget.com/xwidget/widgets/info ... 20/78.html
http://www.xwidget.com/xwidget/widgets/ ... 5/250.html
http://www.xwidget.com/xwidget/widgets/ ... 9/244.html
A wide range of radio stations can be found here http://streamfinder.com/
To get the url you only have to choose a radio station and click "radio streaming links"
download the playlist.asx file (Windows Media) and open it with Notepad.
Copy the (red) url and past it in the radio and click play - it should work now.
Hope this is helpfully & Happy New Year! :)
PostPosted: December 31st, 2012, 10:45 am
I don't get where to get playlist.asx
PostPosted: December 31st, 2012, 11:50 am
you get it by clicking at the red framed link (at streamfinder.com)
http://streamfinder.com/internet-radio- ... ago-chill/
