PostPosted: October 23rd, 2012, 10:48 am
I do not know what it does this feature ...
Someone could explain?
Thank you!
Armando
PostPosted: October 31st, 2012, 9:10 am
I'm new hear but I know what that does.. It 'binds' an object to the parent object as it's tooltip. For example, I selected the control object 'IMG1' as it's bound tooltipcontrol for button 'A'. This results to 'IMG1' being hidden whenever the cursor/pointer is not hovered over button 'A' and visible otherwise, just like the attribute 'alt' on HTML's <img> tag. You get my point?
It's not addiction, it's dedication... #Gaming
PostPosted: October 31st, 2012, 11:08 am
Thanks!! Since I do not speak English well and do not know much about programming ... I was a bit difficult to understand ...
I will make an attempt with some object. Thank you very much anyway!
PostPosted: October 31st, 2012, 9:23 pm
let me illustrate then..
File comment: whenever the cursor is pointed to the button "button A", the image "IMG1" appears..
File comment: and here is the button "button A" with the bind tooltip image "IMG1"..
well you don't see the "IMG1" image because it is currently hidden(because of the binding tooltipcontrol feature)
PostPosted: November 1st, 2012, 1:42 am
Now it's crystal! THANKS for your time!
But then I see no difference with the "! FadeInOutVisibleObj =" or "! ShowHideObj ="
Does the same, right?
PostPosted: November 2nd, 2012, 7:06 am
maybe.. definitely not sure if they work similarly.
PostPosted: November 2nd, 2012, 9:02 am
Ok, then if you discover something new about this, let us know!
