PostPosted: September 13th, 2012, 12:12 pm
I have this problem. The wind output (%curWindSpeed) what measurement unit does it use? km/h, m/s?
PostPosted: September 14th, 2012, 1:56 am
Not sure, but the universal weather speed units are measured in km/h. To be 100% correct you can try and compare the output of the widget with your local weather (just Google you's town's weather)
PostPosted: September 14th, 2012, 2:42 am
Thanks for the help mate!
