It is currently October 23rd, 2026, 4:08 am
 Post subject: Help with options button
PostPosted: September 11th, 2012, 11:20 am
So, I have this script to show/hide some elements but it won't run. In the debug window it won't show any errors. Any idea what it might be?
function options_panicOnClick(Sender)
  if(emergency_shutdown.Visible == true)
    options_panic.Text = "Panic Button - OFF";
    options_panic.Background.SolidColor.Color = rgba(194,44,44,170);
    emergency_background.Visible = false;
    emergency_shutdown.Visible = false;
  else
    options_panic.Text = "Panic Button - ON";
    options_panic.Background.SolidColor.Color = rgba(43,188,61,170);
    emergency_background.Visible = true;
    emergency_shutdown.Visible = true;
PostPosted: September 11th, 2012, 6:27 pm
if(emergency_shutdown.Visible==true) would not run, if(emergency_shutdown.Visible) or if(emergency_shutdown.Visible==-1) is ok .
  else
PostPosted: September 12th, 2012, 1:41 am
Loads of thanks! :D
Users browsing this forum: No registered users and 125 guests
