PostPosted: September 10th, 2012, 3:19 am
Is there a way to create an event when a particular key is pressed? For example if the user presses F10 the script:
run("shutdown.exe -L");
PostPosted: September 10th, 2012, 5:16 am
I don't know how to capture the keyboard input once you had left you widget (im pretty sure xWidget dont support it). But if you will create a new Edit lets call it "editKey" and set the Visibility to false we can force it 8-) to act as a fake key capture (Because i didn't found any outer way to capture keyboard input, correct me here if im wrong). Se define a new function
function widgetOnEnter()
     editKey.SetFocus();
So each time the focus is set to the widget it immoderately activates the Edit box and from here just add to the "editKey" Edit a new function to capture keyboard events
function editKeyOnKeyDown(Sender,Key,KeyChar,Shift)
  print("Key:" + Key);
  print("KeyChar:" + KeyChar);
  print("Shift:" + Shift);
The key value for F10 is "121".
But as we all know there is no documentation for xWidget so there is a possible way to maybe somehow capture the keyboard while the widget on the background or else...
PostPosted: September 10th, 2012, 5:21 am
It's not exactly what I wanted but it'll work for now. Thanks. Again. o.e You're a genius.
