PostPosted: September 1st, 2012, 12:45 pm
hello! :mrgreen:
i have a big problem, i customized my desktop alot and add alot things with xwidget but when i restart my computer, all things is gone - _ - please can some one help me!
thanks!
PostPosted: September 3rd, 2012, 4:40 pm
Hi, please make sure your XWidget is downloaded from http://xwidget.com , you can try to download again from http://xwidget.com and install overwrite to update.
I found some version of XWidget that downloaded from other site had this problem.
PostPosted: September 4th, 2012, 4:37 am
yeah thanks! will try it soon but i customized alot and then after a restart or if i logut and re-login all is gone - _ -
PostPosted: September 4th, 2012, 4:40 am
i alrdy have the latest update...
PostPosted: September 4th, 2012, 4:52 pm
Please add some widget to you desktop ,and restart XWidget , still all gone?
PostPosted: September 5th, 2012, 6:02 am
Tony wrote:
yeah all still gone :(
PostPosted: October 13th, 2012, 4:12 am
buuuump! :(
PostPosted: February 18th, 2013, 2:31 am
Right click on a widget, "Window => XWidget menu => Manage widgets"
You can see the runing and installed widgets, are your widgets runing ?
Just a french guy loving computers ^^ !
Find me on DA : http://bebert135.deviantart.com/
PostPosted: April 24th, 2013, 1:06 pm
yess i can see running... apps
PostPosted: June 7th, 2013, 12:04 am
I've got the same problem.
Downloaded + Installed XWidget from http://xwidget.com
Added + Configured some widgets. => Working well
Made Backup
Exit XWidget
Start XWidget
None of the configured widgets is restored. If I open them again all settings are lost.
If I try to restore from backup, nothing happens.
Backupfile seems to be OK:
[Author]
Name=adbacl3
[Theme]
Count=4
0=6
1=7
2=8
3=9
[widget 0]
FolderName=\\dekher99002sto.ww002.siemens.net\adbacl3$\my documents\xwidget\widgets\quartz clock
left=1676
top=0
showOnBoard=0
lockPosition=0
mouseThrough=0
zoom=50
[widget 1]
FolderName=\\dekher99002sto.ww002.siemens.net\adbacl3$\My Documents\xwidget\Widgets\lumia (eng)
left=1563
top=409
showOnBoard=0
lockPosition=0
mouseThrough=0
zoom=80
[widget 2]
FolderName=\\dekher99002sto.ww002.siemens.net\adbacl3$\my documents\xwidget\widgets\ekerrss
left=1620
top=630
showOnBoard=0
lockPosition=0
mouseThrough=0
curcore=1
width=300
height=220
rsscore1.url=http://www.spiegel.de/schlagzeilen/index.rss
rsscore2.url=http://rss2.focus.de/c/32191/f/533875/index.rss
rsscore4.url=http://www.manager-magazin.de/news/index.rss
rsscore3.url=http://rssfeed.sueddeutsche.de/c/795/f/449002/index.rss
[widget 3]
FolderName=\\dekher99002sto.ww002.siemens.net\adbacl3$\My Documents\xwidget\Widgets\metro_calendar
left=1647
top=209
showOnBoard=0
lockPosition=0
mouseThrough=0
zoom=100
PostPosted: September 25th, 2015, 3:52 am
I'm having the same problem, Whenever I reset the program, or when windows loads My widgets fail to load.
I'm on windows 10 if that's any help. Yes I reinstalled xWidget from the website.
Did anyone find a fix for this issue?
PostPosted: September 25th, 2015, 4:05 am
That's why I stay on Windows 7! :)
Even on my second laptop with win8.1 I don't have this problem.
The Dev is working in the XWidget v2.0 and many bugs especially with new platforms like win 10 will be resolved..
