PostPosted: August 4th, 2012, 1:16 am
Hi
How can I get core tag data values, so I can use them in code
Examples
How can I read the value of the "(netmonitor)%NetAllTotalM" tag ?
How can I reset or clear the value ?
Thank you for any help :)
PostPosted: August 5th, 2012, 5:19 am
Hi meme,
you can use core's function "get" to get tag data values
etc: alert( datetimecore1.get("%day") ); this code will alert the datetimecore1's tag "%day" data value
And , you also can uses the "cmd" function of core to call core's action
etc: shortcutcore1.cmd(null , "!OpenFile"); this code will call the action "!OpenFile" of shortcurecore1
PostPosted: August 5th, 2012, 7:19 pm
Thank you Tony :)
Your assistance is greatly appreciated.
Regards
Meme
PostPosted: March 22nd, 2013, 1:29 am
Many thanks, but I still don't understand how to reset the value in "netmonitorcore1(%NetAllTotalM)".
I would like to have a small button in my widget that clears the value, so netcoremonitor1 starts from "0" again.
I could manage to set the text to "0" but after a second it jumps back to the previous value. :(
Anyone knows how to do it properly?
I'm thankful for any little help.
PostPosted: March 22nd, 2013, 3:18 am
:oops: Found it by myself.
I was thinking and trying in too complicated ways using scripting/object functions etc. It's simply !Clear (in "normal" functions).
Sorry.
