It is currently October 23rd, 2026, 1:11 am
 Post subject: [SUGGESTIONS] XLaunchpad
PostPosted: September 7th, 2018, 11:04 pm
[list=]Tags for pad items that can be found via search box.
Option to activate search box on activate.
Prevent other applications from using activate hotkey.
Icons, background images and whatever other images used should go in one folder and be portable.
More portable friendly:
-Paths should support more portability options, like ".\" = "app path", or\and "DRIVE\" or "\" = "app drive", "..\..\" = "go up two levels", "?\" = "unknown drive letter, looks for path on all available drives" etc.
-Settings files (ini and xml and whatever) should not store full paths if running portable version and portable path is possible.
Pad caption font looks jagged, maybe and option to enable anti-aliasing.
Use tiled pattern file as background[/list]
PostPosted: September 7th, 2018, 11:55 pm
Thank you for your suggestions.
The dev will check it asap...
Topic moved in the right section
