PostPosted: July 29th, 2018, 2:16 am
App ver.: 1.1.6.525
OS: Win7 x64
Problem:
After loading OS, XLaunchpad shows itself.
The startup is correct. But the key "start" is ignores.
How to solve a problem?
PostPosted: August 3rd, 2018, 3:41 am
Sorry, this forum is dead, right?
PostPosted: August 3rd, 2018, 8:07 am
vivapoxa Tony is working on the next version and he will try to fix the bugs.
We have moved our attention to the Android apps but the development of the pc software is not dead.
Unfortunately this forum is not so active (most users use DeviantArt) but Tony and I we check the comments here periodically and we put the reports in our to do list.
PostPosted: August 20th, 2018, 10:47 am
OS: Windows 7
App Version: 1.17.818 (portable)
A new version has been released. The problem is not fixed.
I just want you to understand. This is a problem - after running windows, you need to click on the empty field of XLaunchpad. Everytime. :(
Probably, I will look for an alternative to the XLaunchpad. Despite the fact that I like it, I really like XLaunchpad.
PostPosted: August 20th, 2018, 12:51 pm
I will pass your report to Tony.
Thank you
PostPosted: August 20th, 2018, 7:00 pm
Thanks for your report, I will fix it today.
vivapoxa wrote:
OS: Windows 7
PostPosted: August 21st, 2018, 5:28 am
Good news. Thanks. :)
PostPosted: August 21st, 2018, 10:10 pm
Fixed at ver 1.18, please download from http://xwidget.com ;)
PostPosted: August 22nd, 2018, 1:23 am
Thnank you. Now it's fine. ;)
PostPosted: March 9th, 2019, 3:17 pm
Where can I set this start key? I tried adding start=1 to Settings.ini but it didn't help. Love this application, just needs some documentation.
Users browsing this forum: No registered users and 63 guests
