PostPosted: May 28th, 2018, 3:47 am
hello,i like this app.but there are something wrong with apps icon ,which is extra smaller than other app's icon ,such as “mobaxterm” and "feiq" etc.
could u hellp me to settle this issue?
PostPosted: May 28th, 2018, 10:05 am
Hi. As I know all the icons automatically fit to the spaces. So I think that depends on the icons not on the software.. You can try to edit the program's icon replacing with your own (you can search for better ones through Google images). I think this will help
Users browsing this forum: No registered users and 23 guests
