PostPosted: November 1st, 2015, 10:33 am
After using my computer with Windows 10 for a while (I mean have it on for some time), I switch to this app (xLaunchPad) and I frequently want to open some of the folders where I have my "apps shortcuts" with just a few apps inside, but this action (open a LaunchPad folder) occasionally causes an unexpected application crash. Windows 10 reports me that the application has stopped and brings some dialog window presenting their solution, which does nothing. And that's the end.
I usually use this application like a home for all my stuff (applications, folders and shortcuts), but I regret a little when this kind of thing happens. I hope you can solve it.
And finally wanted to say what a great app this is, and also that you need to keep improving some things so it will be even better than now.
PostPosted: November 1st, 2015, 11:07 am
Thanks for the report. Win10 it's a new platform and many programs have no good compatibility.
Tony will check it as soon as possible.
PostPosted: November 1st, 2015, 2:12 pm
Fine! I'll keep using this application and so I hope it will get improvements soon, not only on the beautiful interface it already has, but also it may need more functionality as well as stability for Windows 10 platform.
Thanks for the quick response.
PostPosted: March 9th, 2016, 3:25 pm
I have the same error. I suggest of using windows mode for drag and drop sourcuts drectly to your page in launchpad
PostPosted: May 20th, 2016, 11:59 am
I am also wirh win 10 but no problems with the app at all. Check the error reports from win 10 when you get crush. Paste it here. It may be some other app causing the error or incompability with driver hardware. I have never experienced that. OR too many pages in the app wich can overload your Ram/virtual memory
Users browsing this forum: No registered users and 23 guests
