PostPosted: December 17th, 2014, 12:30 am
Option to close application when the window is closed (after mouse click or launch application).
I want assign hoykey for launch exe-file.
I don't want to have the application always running.
PostPosted: December 17th, 2014, 12:34 am
And... better hotkey support (I want use left shift+tab)
PostPosted: December 17th, 2014, 3:05 am
All the windows programs work like this medilusr!! It's like minimize a window of a program that you're running. Or using a dock program for windows like Rocketdock. You can autohide the dock but the program will always run in the background.
There is no sense shutdown/restart a program like this. At the end XLaunchpad is a very light program and even slow machines can run it without problem..
PostPosted: December 17th, 2014, 6:39 am
Light cpu usage yes, but not ram (100 MB)
Memory wasted 99.99% of the time.
And It costs nothing to add an option to close the application (add checkbox for option, add "if (alwaysclose) close()" when hide window, recompile, 5 min). All happy.
Regards.
PostPosted: December 17th, 2014, 9:00 am
You're probably using the "High Performance Mode" of the XLaunchpad. It's expermiental (I'm still not clear what is does).
Disable that and memory usage will be around 2-3 MiBs.
If you added some code like this "if (alwaysclose) close()". It is not technically possible. YOu have to listen to mouse events and hotkeys and thus need a memory resident program to hook this. This can be done using a stub program but you will have to wait for 5sec or so for a window to tigger. Not intuitive
PostPosted: December 17th, 2014, 9:34 am
Hi.
No, the "Enabled MAx Memory Mode" is disabled.
The process consumes now 106.24 MB
Regards.
PostPosted: December 17th, 2014, 10:20 am
medilusr wrote:
Hi.
Regards.
The ram usage is totally abnormal! :shock:
Please give some technical info about your pc ..
Something wrong with it..
Users browsing this forum: No registered users and 23 guests
