PostPosted: July 2nd, 2012, 2:52 am
Could you add a feature wherein the contentsof the start menu appear on XLaunchpad. This would be really cool because we would use XLaunchpad as our start menu, you could also add a search file like in start menu.
This is just a suggestion and a step forward for XLaunchpad and it would be cool to be similar as windows 8 start menu
PostPosted: July 3rd, 2012, 12:38 am
Thanks for your feedback,I will try to add in future version
PostPosted: July 20th, 2012, 11:43 pm
Launchy is a free windows search for launch utility and is very fast and cool [www.launchy.net]
