PostPosted: April 25th, 2014, 5:25 pm
Some suggestions
1 - E-mail Notification Like Ipad, Iphone (options to configure skin or theme).
2 - Realtime calendar like Ipad, Iphone (options to configure skin or theme).
3 - Real time mini Clock (analogic and digital) like Iphone, Ipad addons (options to configure skin or theme).
4 - Running indicator lights or Circle notification (like iphone) for program in activity (options to configure skin or theme).
5 - Search feature for Shortcuts Apps in Xwidget (On/Off option).
Best regards.
"I received answers about my previously posted suggestions. I want to thank you for the answers but I think I was not clear or understood then decided to put image as an example".
File comment: Exemple about my suggestions
PostPosted: April 26th, 2014, 12:37 am
There is a separate program, XWidget for that
PostPosted: April 26th, 2014, 2:27 am
@rcnuke, you can use XWidget and XLaunchPad together!
PostPosted: May 2nd, 2014, 3:23 pm
Thank's but see my exemple
PostPosted: May 2nd, 2014, 7:57 pm
If you want these options with XLPdad ok, but as I told you, you can have ALL these functions with a Xwidget widget.
Calendar, clock, e-mail, notifications..
PostPosted: May 14th, 2014, 5:05 pm
Many thanks for the reply.
I'm using both awesome (so much awesome!) software. The request is being made to xlaunchpad may look more like the ipad/iphone in some functions, would be more perfect than it already is.
Xlaunchpad is already very good and i use it a long time (the best)!!!!!
Another question (if wrong post, so sorry).
The team has plans to create some other software?
My suggestion is to create a dock also similar to ipad / iphone to use in conjunction with xlaunchpad, would be amazing. There is no similar software designed for windows.
Which post can I put this suggestion?
PostPosted: May 15th, 2014, 3:09 am
You posted in the " Bugs & Feature Suggestions" section so you're in the right place! :)
From what I know, work in progress:
1) XWidget 2.0
viewforum.php?f=2
2) New version of XWidget Android app and a new Android XWLauncher that will support java script.
Now for the dock, there a LOT dock widgets for XWidget that you can find. Now if you mean dock functions like minimize windows on dock and similar advanced functions, I don't now for the future, but for now I think that you should search for other program like Rocketdock or ObjectDock.
But you can always use all of them! All the XWidget programs are known for the low resources and these dock programs run great even on old systems. ;)
Users browsing this forum: No registered users and 23 guests
