PostPosted: June 22nd, 2012, 5:54 am
Hello,
I have one suggestion for XLaunchpad.
Is it possible to assign letters for each application icon and launching the application as pressing a keyboard key. For example, assigning the letter N for Notepad. Then clicking Ctrl twice to activate the XLaunchpad (or some other way) and then pressing "N". But the letters must be visible so when there are too many icons you don't have to remember them but see what icon to what letter is assigned.
Thanks!
PostPosted: July 1st, 2012, 4:27 pm
Thanks for your feedback, Do you means add search in XLaunchpad?
