It is currently October 23rd, 2026, 4:03 am
PostPosted: June 20th, 2012, 6:38 am
Been using xlaunchpad for a couple of weeks and I have discovered on my laptop (HP ProBook 4720s Windows Pro 7 64bit) that when I close the lid (set to hibernate) when i reopen and log back in xlaunchpad does not respond to the commands set to open it (custom hotkey and hotscreen corner)
I have to kill the process and restart.
It doesn't seem to create any event logs that I can see
PostPosted: June 20th, 2012, 8:35 am
did you check the 'desk mode'?
Users browsing this forum: No registered users and 63 guests
