 Post subject: Clicking on desktop
PostPosted: June 15th, 2012, 12:56 pm
Hello,
I really like Xlaunchpad!
But I got a question.
When you launch Xlaunchpad, you get these icons.
But if you click next to the icons, on an empty place on the desktop, Xlaunchpad stops.
Is it not possible to disable this? So you can only stop Xlaunchpad if you click a special button on the keyboard?
This would be great.
Thanks
 Post subject: Re: Clicking on desktop
PostPosted: June 16th, 2012, 4:20 am
Mantef bang..kunjungi blog aku ya bang http://www.icahbanjarmasin.com
PostPosted: June 16th, 2012, 7:39 am
hello,peter
you can check the "Desk Mode" to make XLP always on.
but, in Desk Mode, you can not show XLP on top when you use other apps,you are supposed to use the "show desktop " function of widows to launch XLP.
Users browsing this forum: No registered users and 61 guests
