PostPosted: September 20th, 2012, 5:58 am
If you run XLaunchpad, there are two pages with icons. You can create more by dragging an icon to the right edge of the screen.
Request:
The ability to create a new page by dragging an icon to the left.
Motivation:
Fresh installation starts with something like:
[common-apps] [drives-and-shutdown]
I want to add 3rd screen. Most practical is to have this layout:
[job-apps] [common-apps] [drives-and-shutdown]
This is tedious, because you need to move all the icons to the right. If I was able to add new page on the left, this would be so much easier.
PostPosted: September 20th, 2012, 9:06 am
Wrong topic.
