It is currently October 23rd, 2026, 4:50 am
PostPosted: August 26th, 2012, 1:32 pm
There is a spelling mistake when Googling XLaunchpad or Xwidgit you can see its spelled incorrectly as XLaucnpad... if you view source you see the title is mistyped.
http://i.imgur.com/9uB3w.png
and
http://i.imgur.com/7HWFQ.png
Tyler
PostPosted: September 1st, 2012, 1:06 am
Thanks, I will fix it now :)
Users browsing this forum: No registered users and 63 guests
