PostPosted: August 19th, 2012, 7:24 am
Hi! I downloaded XLaunchpad and tried it out, and I got bored of it, so I uninstalled it. But now, if I right-click my desktop, the "XLaunchpad" menu item is still there, but if I click on it it says "XLaunchpad not found!". What should I do to make it disappear?
Thanks!
Best regards,
Nutu'
PostPosted: August 20th, 2012, 11:15 pm
install xlaunchpad again, go to settings>others tab and select 'delete desktop rtclick menuitem' and 'delete send to rtclick menuitem'
PostPosted: August 21st, 2012, 3:19 am
Thanks a lot! :D
Best regards,
Nutu'
