PostPosted: August 15th, 2012, 5:58 pm
In the latest version (1.08), if I drag a shortcut into Xlaunchpad, the next time I try to launch, there is no response to my custom hot key combination response and I must reload XLaunchpad to have the hot key work once again. (Hot corners will continue to work even though the hot keys will not) After reloading, the program works fine unless I add another item through dragging.
I'm wondering if anyone else is having this problem and whether there is a fix.
Thanks,
Steve
Users browsing this forum: No registered users and 65 guests
