PostPosted: November 5th, 2019, 1:20 pm
Hi all. Installed xwidget yesterday and the Elegant XW weather widget is not showing the correct 12hr time on the top next to the city name. I cant change it from 24hr time to 12hr time. The bottom time is fine.
Any ideas? Have attached ss so you all can see.
Any help would be appreciated.
Thanks!
Amber
PostPosted: November 5th, 2019, 2:58 pm
Hello. The time next to the city is NOT the current time Amber. It's the last weather update (local) time.
The bottom is the clock and you can switch between 12h/24h from the right click menu. (the weather update time shows in 24h mode only)
So there is no issue there..
PostPosted: November 6th, 2019, 4:50 am
Thanks so much! I love it and was thinking I had an issue. can it be made to use 12 hr time like the clock?
PostPosted: November 6th, 2019, 5:02 am
The update time for the weather, can be shown only in 24h format. It's a known request, so I will pass it to the developer and ask to add it to the next update/s. He has some problems in real life but he will continue to work for pc and Android version asap. Especially on Android that with the last Android versions 8.0+ , and Google that forced up to update the SDK, the app doesn't work well..
Thank you very much for your support and for using my widgets! :)
If you need any help feel free to contact me through here on my profile on DeviantArt.
PostPosted: November 8th, 2019, 12:06 pm
Thanks Im using it on my pc. a windows 7 ultimate. I refuse to update at the moment to 10 :)
