PostPosted: October 10th, 2019, 7:59 am
I am running XWidget on Traditional Chinese OS,that has been known that XWidget does support showing Chinese characters' dates/holiday with scripts(format core data) adding with "cn" after it,ex {Yearcn} ${Monthcn} ${Daycn} ${Weekcn}. The problem is it only showing Simplified Chinese unicodes which is illegible in Traditional Chinese OS.
Is possible that developers also make XWidget showing Traditional Chinese correctly with dates?? Thanks in advance.
您好,
XWidget 可以在日期後加 cn 就可以顯示中文日期格式,問題它是顯示簡體中文的unicodes。在繁體中文系統裡會顯示亂碼,不知開發者可以考慮增加支持顯示正確的繁體中文旳日期格式??謝謝。
