PostPosted: May 19th, 2019, 10:22 pm
If Tony wants to add new weather providers, I recommend DARK SKY where you can generate your own free API key
You could then enter the key in the application and use it.
Of course, do not give up Accuweather. IS THE BEST !!! :)
An example of where it is used is here:
https://play.google.com/store/apps/deta ... wallpapers
PostPosted: May 24th, 2019, 4:02 am
Thanks Slavoo!
Tony is out these days for family reasons but he will check it asap..
