 Post subject: Bug: HTC Calendar
PostPosted: November 18th, 2018, 11:03 am
WRT: http://android.xwidget.com/page/widgets ... endar.html
Good evening,
Recently I downloaded HTC Calendar on my mobile. The highlight (glass tile) upon today's date is a wee bit offset. Would it be possible for you to re-upload an ammended version, thank you.
PS: Attaching a screenshot of my old S5.
http://images.mobilism.org/?di=JLOO
 Post subject: Re: Bug: HTC Calendar
PostPosted: November 18th, 2018, 12:26 pm
Fixed. Please download again :)
PostPosted: November 18th, 2018, 8:16 pm
Good morning,
Thank you. Actually I did try to fix it by moving the Y-axis coordinate of the PNG image, but had failed miserably. I guess there's still lot to learn and comprehend.
Thank you again.
PostPosted: November 19th, 2018, 5:12 am
Using the pc designer and connecting my phone it took 2 mins.
There is a separate option for the today's background image. So moving the Y-axis you actually move only the main png that doesn't fit to this case.
Anyway it's ok now :)
Users browsing this forum: No registered users and 149 guests
