PostPosted: October 5th, 2018, 5:40 am
http://android.xwidget.com/page/widgets ... endar.html
Good evening,
Since I also use the Pro versions of Xanimate Clock; I was wondering whether there's a possibility for you to add a second hand to the clock face of the above Xwidget?
Thank you.
PostPosted: October 5th, 2018, 8:07 am
XWidget supports seconds like Xanimateclock.
Even because all the animated clocks are created with XWidget Designer.
The answer is purely practical. Because if XWidget had the same animated clock widgets, there will be no reason to have Xanimateclock app. We wanted a separate app for animated clocks only and give a reason to the users to try both.
We don't want to have clone apps in our collection and force the users to buy both without a real reason. This will be unfair and dishonest.
At the end don't forget that since XWidget supports seconds for digital and analog clocks, users can always create their own animated clocks! :)
PostPosted: October 5th, 2018, 8:30 am
I comprehend that; but thought that since a couple of clocks that were initially designed for the Xwidget app are now in the Xanimate Clock app with the animated second hand--maybe a version of Sticky ClockCalendar with second hand could also be designed by you for Xanimate Clock app.
Anyway, thank you for the rejoinder.
PostPosted: October 5th, 2018, 12:12 pm
Yes of course. This can be done.
I will put that widget in the list for the next version of XAClock
PostPosted: October 5th, 2018, 12:24 pm
Looking forward to it. :)
Users browsing this forum: No registered users and 149 guests
