PostPosted: October 3rd, 2018, 2:39 am
Good afternoon,
Is there an option or a workaround to use another weather provider other than AccuWeather that I am not aware of?
Or is AccuWeather the sole service that Xwidget can use?
Regards.
PostPosted: October 3rd, 2018, 7:15 am
We're working on it, because all the widgets/ the weather icons codes are created based on the accuweather.com server codes.
So it's a bit hard for practical reasons.
So for now XWidget supports weather prediction from accuweather only.
PostPosted: October 3rd, 2018, 7:45 am
Accuweather is the best weather provider on the World
PostPosted: October 3rd, 2018, 11:11 am
I beg to differ; in my humble opinion MeteoGroup is much more precise.
PostPosted: October 3rd, 2018, 12:47 pm
I've had a difference of opinion with Slavoo on another thread, but, as far as my area is concerned, he's right. Weather Underground and Dark Sky are very good as well. Foreca and many others, not so much. The worse may be Open Weather Map. Of course, this may be one of those subjective topics, as different areas may experience more or less accuracy from a particular weather service. I must admit, though, to not being real familiar with MeteoGroup.
Users browsing this forum: No registered users and 219 guests
