PostPosted: September 16th, 2018, 12:31 pm
I just started using this widget on my Moto G4. I've always liked the look of the Moto standard "Command Center" widget that this one mimics, but the original has no option to refresh manually or more frequently, so the XWidget one is a vast improvement. One request: Is it possible to add the time of the next calendar event as shown here from a screen shot of the original? I have my employer's PC with no option to add XWidget to it, and I don't know how to add a calendar event via Android. Just a suggestion. I'm enjoying using it. Thanks.
PostPosted: September 17th, 2018, 12:07 am
sbs8331 yes I had as base the original one (all the images are extracted from the original. apk), I saw that part with the event, but for now XWidget doesn't support the visualization of calendar events. So for now we can only add a shortcut there for calendar. But I prefered to leave it empty. So I can't do more for now..
PostPosted: September 17th, 2018, 5:44 am
Understood. It was worth a shot. What's the lightning bolt that appears there? Is that a calendar notification? Never mind. I see that it's a charging indicator.
Great widget. Thanks.
PostPosted: September 17th, 2018, 6:10 am
Yes the lighting bolt appears during the battery charging as the original one. :)
Cheers and thanks for the support!
PostPosted: September 17th, 2018, 12:25 pm
I like the one you did best, but this other Moto "Command Center" widget might make a nice supplement
PostPosted: September 17th, 2018, 10:13 pm
Yes a creation of an alternative "EX" version for Android will be nice.. To have 2 to 1 widget I mean. I'll see what I can do..
Users browsing this forum: No registered users and 217 guests
