PostPosted: March 18th, 2018, 6:25 am
The speedfan core is very primitive, probably one of the first that Tony created. What it reports is basically useless. One temperature, probably the highest but that is unknown. It does not tell you which sensor is reporting the information.
Speedfan does not identify the sensors in its shared memory area but they are there too query. Either remove the speedfan core or update it.
Severity : MEDIUM
Workaround : None
PS. I can provide a program that does the same as the speedfan core in Xwidget, however it functions a lot better as it reads all of the sensors. It needs to be run from the command line. Xwidget could use it by parsing the output and delivering the results to the widget.
I already use it in my temperature sensing Yahoo widget.
The source code (cpp) is provided so that you can recompile the code yourself if you want to. The code is written in C.
File comment: A compiled .exe and C code provided
speedfanreader.zip [6.43 KiB]
Downloaded 359 times
Last edited by yereverluvinuncleber on March 18th, 2018, 8:03 am, edited 2 times in total.
PostPosted: March 18th, 2018, 6:41 am
Just as per the Network core, the Speedfan core does not seem to want accept an interval of greater than 1000ms. If you open the IDE and check you will find the value has reverted to 1000ms.
WORKAROUND:NONE
SEVERITY: MEDIUM
In general the speedfan core is so poor as to be almost useless. Users would be better off using my own provided 'core' to Speedfan.
Last edited by yereverluvinuncleber on March 18th, 2018, 9:47 am, edited 1 time in total.
PostPosted: March 18th, 2018, 9:18 am
Jim, please add to the list.
